Things to consider before lowering your EK
So I probably should've searched through a little more, this information has probably been posted I just figured I'd post this about my 96 civic EX been trying to get everything straightened out after I bought the car already lowered. So I bought brand-new tires Rota slipstream wheels and brought it to the shop to get aligned. And the guys like well I'm able to set everything but you should buy camber kit so I went and bought a camber kit, new rta bushings back to the place and the guy was giving me lipservice saying that I also have a little bit of caster adjustment, and that I need a caster kit! and he would have to download some special information To do my camber. I told him I would do the camper myself, And he agreed I should be able to do it was just a level but I was thinking why couldn't he do it with just a level. So I set my camber yesterday and it threw off my toe. So this guy is messing with me right? I'm going back on Monday he better realign my car, or else that yelp reviews going to be ugly!
but anyways just wanted to let you know guys if you lower your car, and you want the ride to be somewhat decent, you need to look into camber caster and scraping your oil pan! ( i've got some serious scratches on my oilpan!)
I never narc'd on nobody!
Re: Things to consider before lowering your EK
https://honda-tech.com/forums/honda-...tions-1998336/
Caster is not adjustable, and does not need to be adjusted unless there is something broken or damaged. You can't do camber with "just a level". There are DIY methods, but it takes quite a bit more than that. Take it to another shop.
Homestly I'm really not worried about the caster, I'm gonna see how it drives I found some bushings that are supposed to help with the caster if I need to go that route. But are used a level and my smart phone with the level app and I dialed my rear camber to zero and I put my front to -0.2, I was going to do zero but I figured it might help me when I'm doing a fast turn. Anyways I brought the car to the shop today and I just realized the tow now my camera until were sad I'm gonna see how it drives I think it's going to be good! 👍🏽 Thanks for the input I also thought that Caster thing was stupid.
Oh and dude if you want to take "fast turns" why did you zero out your camber? Zeroing out camber on a lowered car defeats the purpose of lowering a car.
#1 Super Guy
When doing an alignment, Camber must be set first before toe. The alignment tech should have told you that. Camber should be set at -1.0 for street driving. With too little camber you will find the outer edges of your tires wearing from hard turns. Kinda depends on how you drive though.
Don't mess with caster unless you are having problems with the car pulling to one side or something. It won't wear your tires or cause problems.
Thank you for the input 94 eg I just figured I wanted minimal tire wear, my car is so slammed I have to watch it on the turns, speed bumps driveways ect but my build advisor told me to zero my front camber so I can grip the road better, I just zeroed the rears because I was kind of tired of the cambered out look too. Just felt so much better to look at my tires then being straight. But I notice not my rear tires are closer to the fenders within 11/2"! Yikes I think I'll go to -1 camber thanks! Definitely low enough to get a ticket I guess your car supposed to be over 4 inches off the ground. Here I some pics!
Ok notarcist, why is he an idiot elaborate please, by way it might not be slammed but it scrapes pulling into my driveway. My oil pan is less than 2 inches off the ground and so is my downpipe.,. I just don't have a body kit on the front and rear... here's a video for all you haters lol
Facebook Post
Ok notarcist, why is he an idiot elaborate please, by way it might not be slammed but it scrapes pulling into my driveway. My oil pan is less than 2 inches off the ground and so is my downpipe.,. I just don't have a body kit on the front and rear... here's a video for all you haters lol https://www.facebook.com/derek.perez...59753930918778
I didn't just modify this car I swapped the engine did the clutch replaced my fuel pump, preform did rear disc brake conversion and now I got all 4disk brakes with working ABS after I spliced my ABS sensors. My buddies a street racer who has a fully built b20 designed by bisiMoto and running a75 shot nitrous. trust me Hell probably smoke all you guys on this thread. By the way if you guys want to talk trash on me go ahead but I guarantee half for you guys probably don't even swap your own motors probably don't even like it in your hands dirty. Once I install my Skunk2 alpha series valves and retainers, get my chipped OBD one ECU and then I'm going to the Irwindale speedway and I'm going to hit a 36 shot nitrous I'll let you guys know the numbers it I should be hitting close to 180 hp after I hit my nitrous...
OP: is the suspension coilovers or a lowering springs?
There's always a trade-off of lowering vs ride quality so, you have to ask yourself which is more important to you? Admittedly, a small wheel gap looks nice but is it worth bottoming out and harsh ride over bumpy/lumpy roads, scraping tires, quicker tire wear, potential engine and exhaust damage? Add passenger(s) and makes it even more dramatic. If, your setup is adjustable you might want to find a happy medium between stock and slammed.You might find you don't lose much handling and gain some ride comfort.
OP: you best get your ego in check! Neither you or your build advisor are adding anything new to the Honda world and in fact are just doing mods/swaps that others have developed, written about, You-tubed, etc...long before you came onto the scene. In essence you're just another monkey turning a wrench. NARC may (or may not) have been out-of-line when he commented on your build advisor but, only time will tell on that one. To think and comment that members here aren't capable or haven't performed similar mods/swaps that you and your adviser have done is ridiculous and asinine.
by the way I have lowering springs with Trueheart short struts and SickSpeed tophats. Honestly the ride is better now because when I got the car they just had stock size shocks with lowering springs ever since I installed the truehart sport short struts with the top hats I noticed my ride actually has a little bounce to it which Is ok because my car rides a little higher now.
O.G. triple O.G.
36 shot of nitrous? LMAO.
GTFOH
Wut?
Fish Twig
i sense very strong trolling in effect. My car is almost that same height and I sure as **** do not scrape my oil pan.
- no alignment sheet
- special engineer needed for advice
- still asking an online forum for suggestions even though special tech.
- calling online members haters ( sounds like another HT-GDD member)
O.G. triple O.G.
Tony is right there is no way you're scraping on driveways and **** with a ******* 2 finger wheel gap and 195/55/15s stop trying to sound cool
I want to smash those tail lights in, very badly.
