em1 vs ek9 front lca
are ek9 and em1 front lca the same?
i was planning on getting new arms from honda but there expensive and i found a set of used ek9 ones for half the price
Re: em1 vs ek9 front lca
They are 100% the same since they share the same front suspsension components (26mm sway bar, endlinks, oversized forks, yadda, yadda)
I used to have an EJ6 with EK9 FLCA-swaybar along with EM1 forks... all bolts up the same, both stamped steel.
Maybe the difference in part # is JDM vs. USDM
The compliance bushings of the EK9 arms are roughly 4x as stiff... just buy the "EM1" ones and get some aftermarket bushings if you care about that.
so the ek9 bushings are stiffer then the em1 ones?
im eather getting new em1 arms from honda but there 180 each
or a used set of ek9 arms for half the price
how would the ek9 stiffer bushings feel? i didn't know they were 4x stiffer then the em1
i don't really want to buy aftermarket bushings i usually stick with oem..
but i don't see a part number for them
The Compliance bushings are the only OEM bushings you can buy seperately for the front LCA's.
I also have a used set for sale .....https://honda-tech.com/forums/sale-1...parts-3296249/
Nuck3lz
Honda Civic (2001 - 2005)
12
10-08-2009 04:39 PM
tlkolrod
16
01-10-2007 11:55 AM
civiccpedx
10-19-2004 01:38 PM
