99 civic ex MT - need help identifying engine noise - recording attached
This noise is coming from the engine area . It gets louder as I accelerate. It sounds almost like a buzzing alarm clock.
If any of you can help me diagnose it that would be great. Mechanic is closed and I can't miss work tomorrow so if I need to rent a car I need to figure that out tonight.
Attached mp3 is a recording of the noise.
Update - I've now noticed that turning the steering wheel also affects the rhythm of the noise. Also if I stop mid turn, the wheel starts very slightly jerking the wheel from left to right. The noise matches the rhythm of the jerking of the wheel.
The jerking is related to the wheel trying to pull back to center. When I think left and hold it, it jerks right and vice versa. Also the the noise follows the jerking movement towards center. So if I turn left the noise is on when it jerks to the right.
Re: 99 civic ex MT - need help identifying engine noise - recording attached
Do you have power steering on this car? Check to see if your power steering fluid is low/empty.
I'm assuming from the recording that your car makes this noise even when it's not moving.
Jed
Jed
del sol1658
06-06-2006 12:54 PM
Tuner Eddy
03-01-2005 10:48 PM
pyromaster
05-27-2004 07:54 PM
