Broken valve cover bolt
Old 06-20-2017, 11:54 AM
Jeremy Dunn's Avatar
Default Broken valve cover bolt
By the title and what you see here can i get that out at this point? I tried drilling a hole but as you can see its off center. Or if any of you are in the north Houston area ill pay you 40 bucks to do it for me. Thanks
Old 06-20-2017, 01:32 PM
Hysterically Calm
TomCat39's Avatar
Default Re: Broken valve cover bolt
Usually you center punch the broken bolt to create the start point for drilling, then you use a cobalt drill bit to drill into the hardened steel of the bolt.
Usually an easy out at that point will work as those bolts are typically broken from the user over torquing them and snapping them, not from corroding into place.
Old 06-20-2017, 01:36 PM
So can I still get it out though? This is my daily so I need this car up and going again
Old 06-20-2017, 01:45 PM
mk378's Avatar
Punching first so you drill in the exact center is important. Get a left-handed drill bit. When it grabs the bolt, it will often back it out.
To drive somewhere you can put the cover on with the other bolts (do NOT overtighten) and put duct tape over the hole for this one.
Old 06-20-2017, 03:18 PM
Jimi Hondrix's Avatar
+1
OP: Left handed drill is also referred to as a reverse drill bit in case you have trouble finding one (which you shouldn't). Torque specs for valve cover bolts is (IIRC) 7-9 ft/lbs. A lot of foot/pounds torque wrenches don't start that low so you can use an inch/pound and convert foot/lbs to inch/pounds with an online calculator. A method I use is to tighten VC bolts with extension socket hand tight and then socket wrench drive another 3/4 turn for final tightening.
Old 06-20-2017, 04:41 PM
Hysterically Calm
TomCat39's Avatar
No calculator needed, multiply/divide by 12.
7 ft pound is 84 inch pounds. 12 inches to a foot.
Old 06-20-2017, 08:44 PM
I might plug it up for now. Can I just use a spare grommet and plug up the hole of the grommet?
Old 06-20-2017, 09:02 PM
Stancetard Hate Monger
eghatch9295's Avatar
yeah, you can. i've seen corks, etc jammed in them over the years
Old 06-27-2017, 07:57 AM
So i put the grommet on and covered it up with gorilla duct tape and there are no oil leaks anywhere. Thanks for the help.
Old 06-28-2017, 07:13 PM
Originally Posted by Jeremy Dunn
duct tape
Man's second best friend.
Old 07-01-2017, 09:59 PM
jorge74's Avatar
If you start getting leaking valve cover,
HeliCoil would be a good option I had to do 3 on mines pretty easy to do also.
Potential2nr
01-17-2012 03:47 PM
sde780
22
03-22-2010 11:49 PM
eagleclawracing
09-15-2006 01:57 PM
murmur9
03-10-2006 05:06 PM
LoudAccord
01-09-2003 10:43 AM
Quick Reply: Broken valve cover bolt
