D16y7 Timing Belt Squeek
Hey all,
I just replaced the timing belt on my 2000 Civic SE. Now the belt squeaks at low rpm when I'm starting to drive. It doesnt squeek at idle only when I'm first letting off the clutch. Could the belt have seated itself in and I should tension it up? Thanks in advance.
Re: D16y7 Timing Belt Squeek
Are you sure it's the timing belt and not one of the accessory belts?
Remove accessory belts one at a time to test.
If it is the belt retension per manual or as shown in the video below starting at the 7:20 time mark
