Adding Battery Backup 520T to...
Hi everybody,
I would be grateful for some guidance.
I just installed a Viper 3305v in my 95 Civic DX Coupe.
I've already soldered the hood and trunk pin wires (with diodes) to the brain Trigger wire.
I also just recently picked up the Dei battery backup 520T and read it will need to be soldered to the brain trigger wire via diode as well.
So my question is this - is it okay to splice/solder the backup battery wire (via diode) further up the Instant Trigger wire as opposed to the end of the Instant Trigger wire where I've already soldered the hood pin and trunk pin (via diode) to?
Thank you.
Thank you.
O.G. triple O.G.
Re: Adding Battery Backup 520T to...
If you are going to isolate the (BLUE) instant trigger wire closer to the alarm module, you can add another diode. Just Y-split it, wire without the diode will lead towards the 520t and the one with diode, to the hood/trunk pins.
tangerinebeast
01-05-2011 03:48 PM
