oil leak
oil leak
i have an oil leak(see attached picture), looks like its coming between the engine and transmission. is it an engine oil or transmission fluid? the oil leaking is kinda dark in color.
can anybody help me how to fix it. thanks
Re: oil leak
It looks like engine oil. You'll have the remove the transmission and put in a new rear main seal, but offset it, so it doesn't ride on the same spot on the crank (the old seal probably wore a groove in the crank).
Or you could try using an oil additive to renew the seal instead. Sometimes they do work, but that looks like a bad leak.
Re: oil leak
Re: oil leak
I've had this same problem and thought it was the rear main seal. Have you ever replaced the oil sending unit? That's where my leak was. It's right above the oil filter usually.
Re: oil leak
ok. i'll try to check more where the oil leak is coming out. i notice that leaked oil is too dark, i just did an oil change and the oil on the dip stick is clean and newer.
Re: oil leak
Look for stuff leaking above, like the distributor seal or VTEC solenoid.
The transmission fluid should be pale yellow, like new motor oil. In fact Honda says you can use motor oil in there.
bluemc
03-10-2012 08:44 AM
