TPS Readings High
Old 06-03-2017, 02:21 PM
jorge74's Avatar
Default TPS Readings High
I was testing the tps it stays at a high voltage 4.69 and 4.89 at open throttle i tested all 3wires the first wire is neg , the middle is signal , the 3 is constant power. As to how the car feels well iv been getting a kinda-of a slow acceleration then a at a certain point it wakes up above 3500rpm. No obd codes, plus on the scanner its freeze frame tps 9.8 %. Also i noticed the it has been changed before there are no rivets its a torx .
Any thoughts or suggestions on this ?
Old 06-03-2017, 03:27 PM
Hysterically Calm
TomCat39's Avatar
Default Re: TPS Readings High
No clue what anything should be on the 2017 Porsche you are working on.
Are you sure you are in the correct forum?
Old 06-03-2017, 08:11 PM
jorge74's Avatar
97 civic ex
Old 06-03-2017, 09:08 PM
JRCivic1's Avatar
Remove the two torx screws and properly re-install the TPS sensor making sure that the spring loaded sensor tab is placed between the prongs of the throttle blade shaft. Re-install the torx screws a half turn from snug and set the TPS voltage at .500 volts and then fully tighten the torx screws.
polything
23
07-27-2012 08:23 AM
jake1191
Engine Management and Tuning
07-18-2011 06:42 AM
chrisff521
04-05-2009 07:26 PM
DCxMagus
05-03-2007 06:45 AM
cazper8890
03-02-2007 08:25 PM
Quick Reply: TPS Readings High
