Wire tuck, wont start. Simple question regarding fuse box
Hey guys. I got a 99 dx with a y7. I just did headlight harness, wiper harness, fuse box tuck and battery relocation.
All my electronics work, but my starter only clicks once. My battery ground is good, battery is new and i also tried it with a jumpbox.
Here is a diagram of how my wiring is done.
I think my issue is my power from battery to the fuse box. On this other diagram it shows fuse box TO starter.
Am i supposed to run the starter wire :
battery to fuse box, fuse box to starter?? That doesnt make seem right to me.
O.G. triple O.G.
Re: Wire tuck, wont start. Simple question regarding fuse box
left one to the alternator and the right one to the battery (positive terminal). There will also be a larger gauge power wire from the battery to the starter as well. On a stock car like yours, you should only have 2 power wires at the positive battery terminal and one ground wire at the negative battery terminal.
It should be like your drawing-- two wires fork off of the positive battery terminal, one to goes to the fuse box and one to the starter.
You could jump the small terminal on the starter to battery + and see if it turns (make sure car is not in gear and brake is set so it doesn't move inadvertently). This tests the battery, starter, and the major power and ground wires.
O.G. triple O.G.
Well, i tried jumping the starter and it did the same thing. Just one click. So im kind of lost on what to do from here. Ive checked all my connections, everything is plugged in, no wires accidentally cut or anything. Im thinking it is alarm related?
notnic3
06-12-2017 11:26 AM
chillerice
02-20-2013 07:48 PM
evilho75
05-13-2012 01:35 PM
DailyDriven259
05-11-2012 11:31 AM
