Cracked my valve train.. can I JB weld?
I'm putting things together after I changed my head gasket... everything is going great then bam, I cracked this part while tightening these screws. I pulled the valve train to do work on the head. So I had a couple questions. Any ideas why this happened? And can I JB weld where it cracked? I googled this question and got mixed results. I've looked for just the part I cracked, but it seems like I have to buy the entire assembly.
Car is a 1996 Honda Civic Coupe EX. The crack is towards the bottom of the pic... can't miss it.
Re: Cracked my valve train.. can I JB weld?
You need another complete head. You cannot just replace the end cap where the dizzy mounts. The cam journals are unique and line bored in each head specifically.
-Intl Steve Krew
I know it's not worth it, I just know it should be possible to line bore it true.
But a new used head should be no more than $100.
since it's trash anyway you could try JB Weld or an aluminum specific casting repair epoxy. Devcon is one of them but it's hard to find in small quantities. due to the location of the break, most of the stresses will be taken by the fasteners anyway. on top of that, older non-vtec engines had this as a separate piece. see...
if you do attempt it, everything needs to be very clean and oil-free. follow package instructions and bolt down and torque to spec (and per the sequence) to let it cure in place. it may not work, but this will likely give the best chance of success.
otherwise... new or good used head.
I would try putting it together as two pieces, which as @hondamark said, is how the non-VTECs are made. The part at the very end really just provides a place to mount the distributor, it isn't under much stress. Worst case you'll need a new head, which is where you are now.
It's important to make sure the dowel pins are going into their holes properly as you turn the large bolts to bring down the cam caps.
best guess, the tightening sequence wasn't followed. can you confirm?
If I do try to epoxy this and run it, is there anything else I can cause more damage to if the repair doesn't work? I don't want to cause more harm when I can just buy this for $80...
https://www.ebay.com/itm/96-00-CiViC...~1AL:rk:1:pf:0
Again, a LOT of work and expense just to fix it... did I mention "replace the head" ?!?
Maybe you fix it IF the head has had a ton of money already dumped into it... CNC port work... a 5-angle racing valve job... replacement valve seats that sit proud to reduce valve shrouding... something well beyond stock. It just doesn't make sense to do this to a factory stock head.
Last question guys.. for this project. This bolt marked with the red arrow. It just keeps turning and doesn't seem to tighten. I'm all nervous now after I screwed up. All the other bolts are torqued. Just keep turning it? What is this bolt for?
https://imgur.com/sIZn9K7
O.G. triple O.G.
That bolt holds the rocker/valve assembly. It's not a head stud. HS are at the bottom/lower section of the cylinder head.
Run it, that is not a critical dimension. The cam cams are all doweled and still connected. That broken off piece ONLY supports the distributor and o-ring seal. NBD. Bolt it all down including the broken off piece just remove any loose pieces.
Edit: Oh wait, that is the oil supply galley broken off just under that bolt with the green colored head. She is junk.
O.G. triple O.G.
The threaded hole for that is likely reamed out. You can get thread inserts for it but I would replace the head if I were you. You can find a good reman head on eBay for under $300.
