No taillights - Honda-Tech - Honda Forum Discussion
No taillights
Old 02-13-2019, 03:41 PM
White_EG1's Avatar
Default No taillights
Recently posted a thread about how my horn all of a sudden turned on and stayed on. Had to pull the fuse to get it to stop.
Didnt drive the car for a few days, and now my brake lights illuminate, but donít flash when pressing on the brake. Either side. They worked fine, before the horn issue.
Whats going on?
White_EG1 is offline
Old 02-13-2019, 04:24 PM
Default Re: No taillights
The brake lights aren't supposed to blink, are they?
If you're talking about interaction between the brake lights and the turn signals, that is almost always a bad ground or broken ground wire in the back of the car.
mk378 is offline
Old 02-13-2019, 05:02 PM
White_EG1's Avatar
I mean like they donít come on when pressing the brake. Where would the wire be in the back of the car
Old 02-13-2019, 05:26 PM
Did you pull the horn fuse to make the horn stop? That would also kill the brake lights.
mk378 is offline
Old 02-13-2019, 05:28 PM
tony_2018's Avatar
tony_2018 is offline
Old 02-14-2019, 12:59 AM
White_EG1's Avatar
Yea thatís what I did.... I had to. To get the car to stop screaming. As soon as I put the fuse back in is when the horn turns on and stays on again.
Old 02-14-2019, 04:23 AM
O.G. triple O.G.
NVturbo's Avatar
Brake lights staying on.....BRAKE STOP BUMP PAD likely missing.... above the brake pedal (pedal assembly).
NVturbo is offline
Old 02-14-2019, 06:08 AM
Take care of the horn problem properly and put the fuse back in and viola the brake lights are going to work again because there was never anything wrong with them.
Usually the reason why the horn won't stop is that the wire in the column that goes to the horn button is shorted to ground. If you don't care if the horn works at all, the simplest workaround would be to pull the horn relay.
mk378 is offline
Old 02-14-2019, 06:24 AM
White_EG1's Avatar
Where is the relay located? I donít have the diagram that goes under the dash. A picture would be perfect
Old 02-14-2019, 06:30 AM
BiggieBert's Avatar
BiggieBert is offline
Old 02-18-2019, 02:07 AM
White_EG1's Avatar
Put the 15a fuse back and it hasnít happened since, crazy.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
