gsr swap 2000 civic
Old 02-07-2019, 12:44 AM
Luisaguilar's Avatar
Default gsr swap 2000 civic
Hi there I have a 2000 Honda Civic with a 94 gsr swap I am having trouble with it starting it will crank for about 10 Seconds and then start I am running a obd2 b16 dizzy could this be the problem?
Old 02-07-2019, 09:09 AM
Freedo_Civegra's Avatar
Default Re: gsr swap 2000 civic
I’ve had issues with the fuel pumps allowing the fuel to drain back into the tank out of the fuel rail while the car sets for a period of time. Try cycling the key on for a couple seconds without cranking then back off, then on for a couple and back off, then try starting. If it starts right up after doing this, you have a fuel pump issue.
Old 02-07-2019, 06:58 PM
I have tried all of this and nothing has work I just changed the y8 fuel pump to a gsr fuel pump and still nothing the pump primes but there is still no pressure
Old 02-14-2019, 04:25 AM
Still haven’t found the problem any help anyone? Brand new fuel pump and relay and still no fuel pressure
hermtm2
03-26-2009 07:02 PM
4doorcivic9
06-11-2008 06:31 AM
Cameron60
01-16-2007 06:04 PM
Rice Ball
12-04-2003 09:54 AM
Quick Reply: gsr swap 2000 civic
