Fuel tank question
Fuel tank question
Wondering where the fuel pump is located on the tank? I know it is under the rear seat, but I'm wondering if it sits towards the front of the car and tank, or the rear of the tank? I did the dumbest thing ever today...jacked the rear of the car up to install a new muffler and instead of getting the rear cross member, I jacked up under the far rear of the fuel tank 😤 it was dark in the garage and I've jacked it up many times, but I just fucked up today by not paying close attention. I obviously let it down right away once I realized what I did.
I filled up and dont have any leaks thankfully. I did gouge up the undercoat spray a bit but I re-painted that so it doesn't rust. It's about a 5" circular dent now. Will it cause any harm to just leave it now? Or should I get a new tank?
O.G. triple O.G.
Re: Fuel tank question
you should stop "trying" to work on cars. Seriously....SMH
There will never be a need for you to even lift the car up so far up..., especially on the gas tank. Either lift it at the center tow hook or in front of the rear tires,
If you have any actual advice to help out then I'm all ears, that's why we're all here on the forum.
A replacement tank is a low cost item... I would suggest replacing it so you don't have problems in the future. It is good that it isn't leaking, but caving in the underside can cause problems with internal slosh and proper venting... so even though you said you can fill it up, you have to understand that the tanks capacity is far greater than what is advertised to allow for fluid and vapor volume changes.
Just be more careful where you place the jack in the future... I suspect you have learned a valuable "grown up" lesson.
You're denting that cross "frame" as well by jacking there. Unibody cars should only be lifted at their "hard points" where the metal is doubled up and designed to take the weight of the car.
Sounds good, thanks. I'll probably wait for the weather to warm up here and will do the tank then.
Hasn't had any effect on the car yet. I've got 200 miles on and its reading 1/2 tank now which was normal for those miles. I'll run it to about 300 miles and see how the gauge reacts. So far so good though. The dent may look worse in the picture but is about 3" deep at the worst spot.
Oh look, I can change this
In 2004 I came over a ridge on a remote highway and had to straddle a large round boulder on the road. I hear a loud BANG as I failed to clear it. No damage to the running gear but the undercarriage took a hit - at the fuel tank. I drove it like that until 2012 without issue, save for the fuel level sender being incorrect since I decreased the capacity of the tank. You're probably fine.
