Acceleration issue B16 swap
Curious about this part.
Hey I recently bought a b16a2 swaped ek hatch. I noticed later that this part was a loose. Does anyone know what it is? It connects to the fuel injectors by the rail.
Hey ive got a 99 civic hatch with a B16 swap. I have this issue where at a certain throttle it starts to bog down and struggles pretty hard. But after half a second it picks up like normal and accelerates perfect. Its mostly stock with just a skunk intake and AEM fuel rail. Any ideas would be great.
Re: Acceleration issue B16 swap
Merged as the part might be related to your bogging issue and this is about the same car.
I didn’t think so either and I found that out after a bit of digging around. It’s a super weird issue that I can quite figure out with my limited knowledge of issues like this.
Do you know if it's a stock ECU or if the ECU is chipped?
Have you tested fuel pressure?
Also if the fuel return line from the regulator to the tank is clogged the fuel pressure will be too high.
minime-civic
06-01-2008 04:21 PM
ben1284
12-04-2007 05:49 PM
