1992 Civic VX D15z1
1992 Civic VX D15z1
When cold everything is great.
once the car warms up, I can't drive in 3-5 under 3k rpm's without the car sputtering.
You can either accelerate or slow down, but it won't take hold speed under 3k rpm's.
Yes this is the VTEC-E with the 5 wire O2 sensor.
Re: 1992 Civic VX D15z1
sounds to me like you're just going into lean burn and confusing it with a problem. i could be completely wrong but my 92 vx is similar to what you describe.
there are not enough Z1's on the road anymore, please let it be a survivor.
suspicions (in this order due to price)
plugs/wires
distributor cap/rotor
distributor bearing going bad
O2 sensor close to dead
plugs/wires
Generally misfiring at low rpm and heavy throttle is due to weak sparks. It gets worse when the engine is warmed up and the ECU switches over to closed loop mode, which leans out the mixture. The oxygen sensor can also cause runnability problems on these even without it throwing a code.
I also miss the look on parts people's faces when you have to explain that your civic is not one of the normal ones on their list. (back in the late 90s the VX was only listed in a few aftermarket parts store's listings, this made things suck at times)
Earthworm Jim
12-02-2013 03:38 PM
civictunr_ls
02-23-2005 03:19 AM
