95 DelSol D15B7 Series Automatic, Which Motor Mounts
Hi Again,
I'm embarassed to say I put the wrong info for my DelSol.
My Del Sol is a 95 Del Sol S, Automatic, 1.5 D Series (D15B7)
I need to change motor mounts and all of the ones I see on line are for "manual" not automatic. Is there a difference if it an automatic or manual on the mounts I need?
Re: 95 DelSol D15B7 Series Automatic, Which Motor Mounts
I believe the transmission mount is different. I don't remember which is which but one is 3 hole and the other is two hole?
I should be able to tell you once I get home from work today. It will be a few hours from now if I remember.
--Edit Addition--
Sorry forgot after my long commute home. Will try and look at this in the morning.
--Edit Addition--
Thanks TomCat39!!!
I REALLY appreciate you taking the time to look it up.
You're Awesome!!
You're Awesome!!
I'm so sorry, I don't want to get into details but life is throwing me some serious curve *****. I was tied up all weekend with family. I really need to take some time for H-T.
Replying so the thread is at the top hopefully as a reminder to not let family side track me.
I do apologize for the long delay.
Automatic transmission is the 2 bolt pattern (2 studs with nuts) seen in car below.
Manual transmission is the 3 bolt pattern (2 bolts 1 stud with nut) seen on dolly below with stud removed.
The transmission mount is discontinued from Honda and therefore no longer available as an OE part. This is the OE part number: 50803-SR3-A81
I suggest you check RockAuto and look for the OE part number to order the proper replacement.
j-villani
09-27-2012 01:27 PM
hotimportcrx
11-27-2005 09:32 PM
