1999 EX D16Y8 Rod knock or valve lash or?
Hey Guys,
OK, I think the engine is going. Ive developed a bit of a tapping sound which is most noticable at around 3500rpm and gets louder above say 4500 which I now keep the car in the low revs as much as possible as this is my daily and without it Im F'd. Its also my 6 Hr commuter home to Southern Oregon. The sound is mostly only noticable when off the power. On power it sounds pretty normal. Ive checked the valve lash and was really tight as its the first time checking since I put new exhaust valves in after burning one on a road trip. I would think a loose rod would rattle at any rpm but the motor runs pretty smooth at idle. Any suggestions? Sticking valve maybe? It sounds like its coming from the upper part of the engine at least while Im driving and also seems to come and go some and is mostly not even noticable when its cold. Could it be my oil pump? 250K miles? Would it not have a oil pressure light?
Thanks!
Thanks!
Re: 1999 EX D16Y8 Rod knock or valve lash or?
Did a quick search, I see now what they are. Do D-Series have them? I see them on B-Series......
OK. Did a quick Youtube search for LMA's. Wow! I didnt even know these things existed! I feel really confident this is my issue now. Hondamark35, thanks for the hint that may have put me on the right track! Much appreciated!
-Sharmon
-Sharmon
if it burns oil badly then you probably have a valve seal or ring problem.
Should take care of that.
But if the engine is just loud on the top end its probably the LMA's as someone else mentioned.
O.G. triple O.G.
It's likely the 4 LMAs. I had to swap out mine the other day with the ones from my old motor.
- remove spark plug wires
- remove ground wire from valve cover
- remove vacuum hose at corner
- remove valve cover
- remove (10) 12mm bolts of the LMA holder
- remove the (4) LMAs and replace them with good ones
Installation is in reverse.
*** Torque the 12mm bolts to 14ft lbs. Yes, there is a sequence of how they should be tightened/torqued down. ***
B series VTEC engines have a total of 8. Same diameter size but shorter in length...meaning THEY WILL NOT WORK in a D series.
NVTurbo, Thanks for the direction! H-T is the best. So much knowledge!
Jimster480 Going to look into it this weekend. Thanks!
O.G. triple O.G.
any time man. Don't forget to apply some assembly lube to the "new" LMAs prior to re-install.
You can disregard #11-14 since those bolts are not a part of the LMA holder.
Noobatized
04-06-2014 11:49 AM
Kyles ej1
23
09-01-2005 05:05 PM
SwampThing
05-15-2004 12:16 AM
