Question? Crank sensor wiring for swap
Heu guys, I’m sure there is a post on this. But my question is this, I am doing a obd2 GSR swap into a 98 civic EX. Ran into a little snag. The crank sensor by the crank pulley of course does not plug into or match the ex harness. Due to the plugs not matching and the EX is a 3 wire and the engine harness is a 2 wire. I’m running a obd2 p72 ECU. What do I need to do. Thanks..
Re: Question?
Un-pin the three wires from the three wire engine harness CKF plug and un-pin the two wire plug on the GSR engine harness. Tape back the brown wire on the civic engine harness and insert the two remaining wires into the grey plug removed from the GSR engine harness. Plug it into the sensor. Done.
damianw22
11-12-2013 12:57 AM
98ej8coupe
01-28-2008 09:05 AM
backagainracer
12-24-2006 03:59 PM
