Vtec problems after camshafts swap
Old 03-06-2019, 04:15 AM
JAndrinich's Avatar
Default Vtec problems after camshafts swap
Hey friend, I hope you can help me with this mystery:
i have a ek4 civic with b16a2 engine. Recently I swapped my oem cams with a buddy club stage 3+ cams that I have from my old eg6 (b16a2 engine) because I’m seeking for more power in the ek4, but for some reason when I put this cams in my Vtec stops working or at least I don’t notice the engagement (not sound and not more power) but it still revs up to 8500rpm. I’ve already test Vtec oil pressure (65psi), tested Vtec solenoid (it clicks), changed oil (5w-40), change MAP sensor, etc and the only solution I found to make Vtec work again has been swapping again the oem camshafts.
any idea what could be happening?
i must mention that de bc 3+ cams where working perfectly in the eg6 before.
thank for you help!
Old 03-08-2019, 05:06 AM
Loves Tossing Salad
09chaplak's Avatar
Default Re: Vtec problems after camshafts swap
Perhaps you installed the valvetrain incorrectly. Aren't there pins within the rockers that add pressure when the solenoid is engaged?
Old 03-08-2019, 03:33 PM
JAndrinich's Avatar
do you refer to the pins that lock the rocker arms? Maybe being in a wrong position?
Anyways would it make to engage Vtec with oem cams but not with the aftermarket ones?
951parts
K Series
10-26-2010 07:43 PM
projectef
53
09-18-2010 03:53 PM
EARLdaSQUIRREL
05-24-2009 05:16 AM
7mile
38
02-15-2006 06:59 PM
JBk24crx
02-08-2005 12:31 PM
Quick Reply: Vtec problems after camshafts swap
