Need help identifying plug
What is this plug for ? Trying to clean up previous owners mess. I have no ac. And also I am running HIDS. Everything works perfectly fine. I also have a second pink connecter that nothings connected to with a ground wire coming from it. Any info would be appreciated thank you.
Re: Need help identifying plug
It is not stock on a Honda. I dare not speculate as to what it is and why it is there. Maybe a pic from further out to see what is around... it may help.
however this is what the bay looks like.
On the left side of the headlight. You can see the two plugs. Blue & pink. (Not the capped ones)
I relocated a lot of the wires. I didn’t cut any of them. Just moved them out of the way. It was a huge mess.
Now the only things I have there are hids plugs.
Im just so confused on what the pink plug to blue is.
I also have a second pink plug on the right side headlight that’s not connected to anything with a ground wire coming out.
Does any of the wiring in question connect to the HID's (headlight wiring) ??? Some HI/Low beam HID's have a crossover sub-harness that typically only connects on one side.
Actually you just sparked something. if I remember correctly last summer I had a issue with my lights & blinkers not working. But everything worked with the hazards though. I believe the plug that it may be for my lights.
will double check when I go to put my manual rack and give more info
