P2T immobiliser?
Old 03-04-2019, 07:59 AM
Default P2T immobiliser?
I am doing a swap on my 1999 Honda Civic EX and have a few questions.
Most important question. Does the P2T have an immobiliser? If so how do I go about removing it.
Can I use a B20 2 post mount on a B16A2 with my OEM mount?
I do not need a jumper harness for the P2T. The 1999 Civic uses the same plugs. True or False?
Thanks for the help.
EJ8Pedro is offline
Old 03-04-2019, 08:08 AM
1999 Civic Si's Avatar
Default Re: P2T immobiliser?
Assuming you are using a P2T-A11 or A12 from a USDM Civic Si it doesn't have an immobilizer in it. I don't know about the b20 post, there is a lot of back and forth as to if it will work correctly or not on this forum, I will let someone else answer that. If the EX is a manual it should be plug and play, I believe you will need to extend the wiring for vtec and the plugs for the distributor are different (this can be fixed by getting a jumper harness or repining the plug on either the distributor or the engine harness).
If I am wrong on the plug and play part, hopefully someone will correct me. Its been awhile since I have messed with this stuff. lol
1999 Civic Si is online now
Old 03-04-2019, 09:12 AM
tony_2018's Avatar
Yes, the usdm crv driver side post mount will work
No, the P2T ecu died not have an immobilizer
tony_2018 is offline
Old 03-15-2019, 06:27 AM
Ok thank y’all for the help. Have not swap it yet but will confirm.
EJ8Pedro is offline
Jvelez1216
03-14-2016 08:51 PM
bungdogjb
12-08-2015 05:27 AM
JDMEMone
03-26-2015 07:25 PM
CodyGt3076r
01-25-2013 09:58 AM
cas95
11-20-2006 01:12 PM
Quick Reply: P2T immobiliser?
  • Ask a Question
Question Title:
Description:
