Non-Vtec D15b Crank
Non-Vtec D15b Crank
I have a Non-vtec D15b engine sitting around and I was wondering, since I just spun a bearing in my Vtec D15b, if the crank in the non-vtec is the same as the Vtec D15b.
Re: Non-Vtec D15b Crank
Unfortunately, I gave both my local and the main branch of US Honda Motor Co and they both told me that they can not get any information on the JDM engines. If anyone has any info that might be helpful please go ahead and post, other then that I'll go back to trying to search for a needle in a haystack.
Seagull Management
The cranks are different. D15B vtecs use larger rod journals (the same as a Z6, but smaller main journals (like a D15B7/D15B8) There is no USDM crank you can use.
Yeah I understand that USDM cranks can't be used, what I'm saying is I have a JDM Non-Vtec D15b engine and I'm trying to see if the crank is the exact same as the JDM Vtec D15b.
Seagull Management
JDM D15B non vtec cranks are exactly the same as a D15B7/D15B8 crank, so no they aren't the same and it wont work. The D15B Vtec crank is exclusive to that engine, its a real oddball.
Ef_Life
06-02-2015 05:57 AM
