injector wiring issue
Old 06-29-2010, 03:38 PM
92civtegra's Avatar
Default injector wiring issue
1995 civic SI body
B18c1 engine
for some reason my number 1 injector wire has constant signal holding the injector open whenever the car is in ignition position
i replaced my ecu, so thats not the issue... i put a volt meter in the injector plug and whhenever its in ignition on there is voltage on that plug but no others
any ideas?
stock engine and car side harness's with a B18C1 engine, had engine in a different body and had no issues. im almost thinking there is a pinched or shorted wire somewhere in car side harness?
Old 06-29-2010, 03:41 PM
b18cKoupe's Avatar
Default Re: injector wiring issue
sounds like you're on the right track, if the injector is constantly grounded you must have a short to ground somewhere between the ecm and the injector.
Old 06-29-2010, 04:46 PM
92civtegra's Avatar
alright so you think the short is on ground side? i have no idea how the wiring is setup with those, is it basically just a wire from the ecm to injector then a wire out to ground? or are there switches and relays somewhere in there? and is the power side wire straight from the ecm to the injector or is it from somewhere else to the injector
Old 06-29-2010, 05:42 PM
D16SiHatch's Avatar
injectors always get power, ecu sends a ground pulse to trigger the injector to fire. no external relays or anything like that involved. for whatever reason the ground side going to the ecu for that one injector clip is shorting to the body which is causing it to spray constantly.
Old 06-30-2010, 05:19 AM
92civtegra's Avatar
Awesome thanks man. So will it be a power wire from the ecu to the injector along with a ground or just the ground from the injector to the ecu
Old 06-30-2010, 07:09 PM
D16SiHatch's Avatar
just ground. the power comes 1 wire at the ecu which then goes to the resistor box (if applicable) where it's then split and sent to each injector.
reww86
10-28-2018 01:14 PM
hyper em1
01-31-2007 09:46 PM
RTW DC2R
12-16-2006 04:16 PM
Tippyman
14
03-27-2006 08:55 PM
civbeater90
11-26-2002 03:05 PM
Quick Reply: injector wiring issue
