Rear toe camber bolt threaded.
Ok so i was changing my toe camber to an integra one and i over tighened the bolt and it threaded. i put some white stuff over it to catch the thread so it could go back in the body of the car and it worked a little but i just can't fully tighten it as i could the one next to it. The camber feels firm as if it will not fall apart. but in a case like this, what should i do. should i put a size bigger bolt in it or what. Please help!!
Re: Rear toe camber bolt threaded.
you mean stripped the hole?
i think you may have to user an oversized bolt to make new thread
cant retap the hole unless it misthreaded i think
i think i only mis threaded the screw because i cant just push the bolt in the hole of the car so that tells me the body hole is not treaded but the screw. Am i correct?
if you can thread the bolt into the hole but when you get to the torquing phase and the bolt just spins ...
theres no thread left in that hole
and i dont believe retapping the hole will bring the thread back
google it
google it
i just googled it,
people say you have to buy a helicoil and slightly larger than before and make new thread so you may use a larger bolt
blackdc5
Welding / Fabrication
13
05-09-2006 11:21 PM
A.E Motoring
01-05-2006 08:42 PM
StRacer
10-06-2004 06:11 AM
