VTEC ISSUE please help
Hello Fellas, 2 days ago I had an issue with my VTEC, I have a B16A SIR II swapped on my hatch. I take off the throttle for cleaning, I disinstalled the TPS and MAP sensors, when I when you put everything in its place appeared the code 7 (tps) and was out of calibration, a friend of mine helped me to calibrate it, TPS was poorly calibrated (0.47), then I went to drag race when I was burning tires using launch control and I hear the vtec activated but then I repeat the burning tires and rpm not go up to 4500 rpm and vtec did not activated. No code appeared and the oil level was correct. Yesterday I changed the solenoid for one of B18C and then calibrate the tps again to 0.5 and the engine feels good
Being miscalibrated TPS could have caused the vtec not activate and revolutions do not go up in 4500?
Please if someone had the same issue before, help me out!!!! It is very confuse.
Thanks in advance!!!!
Re: VTEC ISSUE please help
cates_07
13
02-20-2006 08:25 AM
ATS_Antone
09-06-2002 08:43 PM
