AXLE HELP. EJ W/ 2ND GEN JDM B16...
1 Post
just wondering what axle i need to run... i have a ej coupe, jdm 2nd gen b16 motor... put a b16 axle in driver side, fit perfect... passanger side is an ls axle, seems short for some reason... tranny fluid around/on axle and bottom of tranny...
should i just get a b16a2 axle for passanger side? even tho its for a ek... or should i get del slow axle?? confused...
Re: AXLE HELP. EJ W/ 2ND GEN JDM B16...
i have had my siR2 swap in my del sol and then in my ej8 with the same axles that came from hmotors, so i would assume that the em1 or delsol vtec would work fine.
any b-series axles will work fine. you prob have the leak due to a bad gasket. it is prob torn causing your leak issue. take the passenger side axle out and check your gasket on the tranny. that piece, your best bet is to grab one from the dealership cause autozone, o'reillys, and napa don't carry the correct part. it will run you about $20
1 Post
thnx... yea i thought about it and remembered there is that seal right there...gasket ordered already, i'll update when i get it and pop it in...
thanks guys!
thanks guys!
DelSol-B18
20
06-20-2012 01:30 PM
