Need Help Deciding My Swap
I have 2000 civic si and i wanna put a swap in it and then turbo it, i was thinking about just doin the b18c1 gsr but could i do a b18c5 and turbo it? The c5 has a 10.6:1 and the c1 gsr has a 10.0:1 Compression Ratio so I was just curious if anyones turboed a c5. I only wanna run like 8psi max on it so let me know if you got anything to help me out thanks. I'm open to ANY suggestions related to the swap, and also money isnt that big of an issue so let me know what you think thanks.
Re: Need Help Deciding My Swap
well i would deff go with the c5. higher compression means better boost results from what ive seen. i may be wrong. also its better overall lol. cmon gsr v's usdm type r?. 8psi is prolly the max u can put on a stock motor anyways. but i suggest some minor engine work like cams and little things like that.
Jackieboy420
11
06-30-2010 05:03 AM
