Helping A Friend. Need Torque Spec!!!
Hi, I'm trying to help a friend out. Her harmonic balancer has a loose bolt and it obviously needs to be tightened, but i dont have any desire to go buy a haynes manual for a car thats not mine (and she doesnt have one) and that I'll only need once. Can some one help me out?
318 Curves, 11 miles
Re: Helping A Friend. Need Torque Spec!!!
Do you mean the crank pulley? On Civics at least, I think that the harmonic balancer *IS* the crank pulley.
If that's the case, it should be the equivalent of about 134ft/lbs on pretty much all Civics. On my B-series manuals, it says 135, but on the 96-00 Civic manual I just checked, it says 90 degrees past 14ft/lbs, which is probably close to the same thing. To clarify, the manual says to tighten it to 14ft/lbs, mark it with a Sharpie, and then turn it 90 degrees past the mark.
Strangely, the 92-95 Civic manual says 134ft/lbs also, and those engines are similar enough to the 96-00 as not to matter in my opinion. I'd say that 135-ish is just fine for all D and B series engines.
It is keyed - hopefully the key didn't come out and get lost. Also, you'll need something (there's technically a special tool) to hold the pulley from turning the engine over while you tighten/loosen it. You're also supposed to lubricate the threads with engine oil.
eh2_Trav
03-03-2017 09:59 PM
