HELP! IAC AND TPS CODES....OBD1 B16
Old 07-01-2010, 08:31 AM
z06eateR's Avatar
Default HELP! IAC AND TPS CODES....OBD1 B16
ok...95 ej coupe, jdm 2nd gen b16... idle is between 1500-2000rpm warmed up. i adjusted timing and idle screw with ecu connector jumped... then, even tho there is no cel on the gauge cluster, i checked just to be sure, and ecu is throwing code 7-tps and 14-iac , so, i think the sensors are just plugged in wrong... does that sound right?? there is also another sensor that hangs below the intake mani that goes to nothing...not sure what this sensor is for???
any help is appreciated...thnx
also, when u are adjusting the air idle screw on the TB, i know u jump the connector on the ecu, start car, warm up car, then unplug iacv, ...but what do u want the rpms to be set at with the iacv unplugged???
thnx
z06eateR is offline
Old 07-01-2010, 08:46 AM
dpetro1's Avatar
Default Re: HELP! IAC AND TPS CODES....OBD1 B16
thnx
idle should be set to 400 with iacv unplugged. sounds like you have a sensor plugged incorrectly. if you are unsure about loose plugs you can use a multimeter to trace them back to the ecu
dpetro1 is offline
Old 07-01-2010, 08:52 AM
z06eateR's Avatar
righton. thnx man! ive done swaps and im pretty savvy...just wanted to make sure the idle with iacv unplugged. im am pretty positive the sensors are swapped since they both fit the tps/iacv...i'll swap em around, adjust the idle and re-shoot the timing after work! i assume i should adjust idle before shooting the timing, correct?
z06eateR is offline
Old 07-01-2010, 07:36 PM
Former User's Avatar
This is a double post.
Former User is offline
Old 07-01-2010, 07:49 PM
z06eateR's Avatar
yea bc i posted more in detail information on this one... i need helping fixing this problem ...just dont wanna go spending unecasary money on parts i dont need if i dont have to...
z06eateR is offline
Old 07-02-2010, 07:36 AM
z06eateR's Avatar
OK..well...my other thread got deleted and im still having problems with my idle...i guess since it was a double post. sorry HT.
anyways, im gonna pull iacv off when i get home and clean it...see if that works, if not, i'll check the voltage at the ecu, but what pin is the tps???!!! guess i'll just try new tps/iacv and go from there... fml!
z06eateR is offline
Old 07-02-2010, 11:10 AM
dpetro1's Avatar
do not go buying new sensors until you are positive the wiring is correct. new sensors expensive and may not fix the problem if the wiring is junk.
obd1 ecu pinout
http://www.ff-squad.com/technet/wiring.obd1.htm
engine wiring diagram
http://repairguide.autozone.com/znet...5280061b2a.gif
dpetro1 is offline
Old 07-02-2010, 11:24 AM
z06eateR's Avatar
sweet!!! thnx for the links!!! will post results...
z06eateR is offline
Old 06-22-2012, 02:01 PM
Keyboard Humorist
4drEF's Avatar
Still waiting for results.
4drEF is offline
Old 06-22-2012, 03:38 PM
Technical Hero
HondaPartsHero's Avatar
What colors are wires going to you TPS and IAT?
HondaPartsHero is offline
Old 06-22-2012, 05:45 PM
Old thread closed.
z06eateR
07-01-2010 07:55 PM
traxxasx
10-11-2007 12:50 PM
luciffer
05-01-2005 11:25 AM
B1692LS
02-22-2005 08:58 PM
chirp2hrd
09-16-2002 05:42 PM
Quick Reply: HELP! IAC AND TPS CODES....OBD1 B16
