Shift linkage for GSR
Old 06-30-2010, 06:42 PM
Civic483973's Avatar
Icon2 Shift linkage for GSR
I have a GSR trans im dropping in a 95 civic. Is the shift linkage the same as the factory one in the 95 civic?
Old 06-30-2010, 06:45 PM
shortstopNE's Avatar
Default Re: Shift linkage for GSR
You have gsr b16 or ls motor this is going on as well correct? Shift linkage will be form a 94-01 integra or hasport/innovative sell their own linkages as well.
Old 06-30-2010, 07:13 PM
ek4_b16a's Avatar
hope so...if not, this swap won't work at all unless you have a special trans adaptor. the d-series shift linkage won't work on a b-series trans.
Old 06-30-2010, 07:21 PM
Master Detailer
98civdx's Avatar
You Need B Series shift linkage
Old 06-30-2010, 07:45 PM
are all b series shift linkages the same?
i have a gsr trans and b20/vtec going in all at the same time
Old 06-30-2010, 11:21 PM
thumper64's Avatar
The D series linkage will work if you CUT it and reweld it. I believe you have to take out 1 inch from both pieces.
Old 06-30-2010, 11:56 PM
92bseries's Avatar
dont do what he says^^^^^ buy a linkage from a del sol vtec model, or from a 94-01 gsr/ls
Old 07-01-2010, 03:09 AM
Seagull Management
94EG8's Avatar
It can be from any '94 - '01 Integra or '99 - '00 Civic Si
Del Sol VTEC linkage wont work, its too long.
Old 07-01-2010, 11:06 AM
92bseries's Avatar
umm i dont think its too long i kno some1 that used it on a hatch, so if it worked for a hatch it should work for a coupe
Old 07-01-2010, 12:51 PM
ramonjones16's Avatar
The del sol linkage IS too long. I know this because when the GSR tranny is mounted the delsol linkage surpasses the shift fork by 2 inches. You are better off picking one up from a reputable dealer or doing some searching on craigslist. For what 94EG8 said for car models. I will say that b series linkages are getting harder to find though.
Old 07-01-2010, 01:01 PM
Master Detailer
98civdx's Avatar
No, your wrong hes right. It would have to be modifed to fit, thats the only way.
Old 07-01-2010, 01:13 PM
Word
Old 07-01-2010, 03:19 PM
Crazy Honda Guy
Deetz's Avatar
this exactly!!!
used integra shift linkages are cheap and easy to find
Old 07-01-2010, 03:32 PM
thanks for the help this will save me some money$
shouldnt i be able to easily find on at a junk yard?
Old 07-01-2010, 03:43 PM
Crazy Honda Guy
Deetz's Avatar
i did...at the local pick n pull, cost $12
Old 07-01-2010, 04:12 PM
do you have to bring your own jack to pull it and tools to pull it?
Old 07-01-2010, 04:17 PM
Crazy Honda Guy
Deetz's Avatar
Decent junk yards have to cars jacked up already so you can slide under neath. Bring 10,12 and 14 mm sockets, 12mm wrench and a hammer and dowel pin remover to get the job done
Old 07-02-2010, 07:51 AM
ok for the dowel pin remover can i use a 1/4 inch punch
Old 07-02-2010, 12:29 PM
Master Detailer
98civdx's Avatar
1/4 or 8mm punch will work.
Old 07-02-2010, 08:27 PM
ok thanks a lot
civichatcht
03-19-2009 06:50 PM
89bsixteen
06-23-2006 03:50 PM
SupraRXZ
02-09-2006 04:35 PM
gtowni3
11-08-2005 06:31 AM
G U E C O
08-18-2003 10:36 PM
Quick Reply: Shift linkage for GSR
