IDLE Problem, almost dies, Not the IACV, No CELs
Helping a friend with a 2000 Civic Ex. The car has no check engine lights and no vacuum leaks. Once the car reaches operating temp at a stop the engine will drop to roughly 400 rpms idle speed and almost stall. At this point the whole car shakes due to the extremely low idle. Eventually the idle will pick up to around 1000 rpms and then it drop again to 400 rpms and repeat the same issue over and over again..
I've replaced the Idle air control valve and it didn't fix the problem. I figured it wouldn't but I wanted to rule it out. Any issue I've had relating to an IACV problem usually causes rapid idle fluctuation from 900rpms to higher rpms. This car just wants to stall but it doesn't.
If I disconnect the TPS sensor, the problem does not occur. It will idle around 1000 rpms and obviously the Check Engine Light will appear.
Any input on the problem is appreciated
Re: IDLE Problem, almost dies, Not the IACV, No CELs
Check whether the TPS output voltages are properly calibrated and, if so, then adjust the idle speed to spec (see FAQs sticky for proper method).
http://www.youtube.com/watch?v=Aid5rDnc2Bw
car wont idle with missing or bad 02 sensor dont skip that even if everything else is perfect. both o2s if you need em obd1 uses 1
MyEj1Broke
01-10-2014 08:09 AM
