need help with h22a jdm swap into 93 Del Sol
well i got this h22a jdm from this guy said it was his sons so he dint now anything about it. and he let it go for 500 engine and trans so my question is i now ive been researching about axles and **** but cant find anything on ecus and wiring harness which ones should i use im droping it in a 93 del sol. or wat yall think i should do sell and look for something els or keep going with swap. thanks in advance for your help
Re: need help with swap
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%2A%2A%2Ah22a-into-civic-eg-ek-information-post-all-h22a-hybrid-info-here%2A%2A%2A-650329/
hope this helps... taken directly from the stickies in the hybrid section
Re: need help with h22a jdm swap into 93 Del Sol
you will use your stock engine harness that matches your car, not the motor, and make the needed modifications.
and does it matter the year of the ecu and thanks that helped alittle ill look over it again thanks
RICE_CR
03-24-2006 06:51 AM
