help with bseries swap in my ek
need help i got my engine harness modified to run obd1 dizzy and alternator .... for some reason without my ecu connected no key in the ignition when i connect the alternator the dome light and all the lights onj the gauge cluster turn on... what could this be...
Re: help with bseries swap in my ek
wiring was messed up? post pics of describe what your alternator plug looks like. in other words which wire is in which location. if you need a new harness i can and make new swap harnesses. check my sig below
i got the obd1 plug on my obd2 ek harness i got the wiring as follows...
blk/yellow-blk/yellow
white/blue-white/blue
white/green- white/yellow
white/red-blue
white/red-blue
So I can make sure you did it right, what order do u have them in. Looking at the back of the plug (wire side).
Top of plug where u unclip from
(1)(2)
(3)(4)
(1)(2)
(3)(4)
this may sound dumb, but do u have all your grounds connected, espessially from the valve cover to rad support?
I had a civic act REAL crazy when i forgot to connect that a few years back... I would push the horn and the lights on the dash like turn signals etc would light up but horn didnt honk, also car wouldnt engage starter sometimes... connected the VC to RS ground and all the weird issues went away and car opperated normally
yea i have the valve cover to chassis...tranny to chassis... and the one from the harness that goes around the thermostat housing ive done multiple succesful swaps but this my first swap where i modified a harness to run obd1 alt and dizzy on a obd2 car
I would deffinately say it's wired incorrectly get a wiring diagram for both obd1 and obd2 alternators and distributors and verify your wiring all the way back to the engine harness and don't just rely on the color of the wire verify what each wire goes to like what wire go to the voltage regulator on your alt ect. it would appear you have a ground some where out of place good luck in the search
Alex Preece
10-03-2018 07:36 PM
Dead CIVIC
15
01-28-2008 05:53 PM
Stylinhonda
09-25-2005 04:19 PM
