How to remove the Bitch pin in less than 5 min.
Location: Pensacola, FL and every Court House in Louisiana
You need a c-clamp, a 12mm bolt and a socket. The socket is to allow room for the bitch pin to be pushed into. Put the bolt on the opposite side and tighten the c-clamp until the pin is out. Hours were spent before this came to mind.
Re: How to remove the Bitch pin in less than 5 min.
its sounds similar to how you would normally install a lower ball joint, but instead of pressing it in, your pushing it out
Yeah I was to the point I just wanted to be done but basically it would be something like... Hope diagram helps
If you tighten the C- clamp it will push the bolt into the shift linkage removing the B.P.
_ top of C-clamp.
T-bolt
O-shift linkage
U-socket to catch bitch pin
_-bottom of C-clamp
_ top of C-clamp.
T-bolt
O-shift linkage
_-bottom of C-clamp
ive seen a tool made already if u search check here : http://www.performanceforum.com/wesv...tch/bitch.html
I was told to use a 12mm bolt to tap it out before I even started but it didn't budge. I didn't have the room to work. I like the screw bit idea, less to try and keep in place while tightening. Wish I would of seen that link prior, would of saved a few hours
took me about 3min to come up with the idea of using a 1/4" rachet extension and a hammer the first time i did this.
matco is who makes the correct tool for the bitch pin. buy one, this is a nightmare without it
http://www.matcotools.com/catalog/pr...MER-LINK-TOOL/
i never come in the civic forum, just noticed this as a top thread and thought i would share a way to save hours of frustration for $26.70
Last edited by TomCat39; 02-15-2015 at 10:24 PM. Reason: fixing url to be the tool and not a page that the tool may or may not be on anymore.
Sure it's a little tight under there, but there is enough room. Well, for me.
yeah make a video next time i guarantee i can take it out faster than you with a air hammer
using a cclamp is retarded
I've always used a honda a/c compressor bolt with no issues. It's roughly 4.5" long with a 12mm bolt head and they're 4 of them that mount the a/c compressor to the a/c compressor engine block bracket. The tappered end fits directly into the "bitch pin". If it's been a while since it's been removed soak it in wd40 then lightly hammer it out.
I was pulling my engine out a few weeks ago and couldnt find punch to get the pin out. So I started digging around the garage and pulled a spare b-series valve out of a junk head that I had laying around.
Put the top of the valve (small end) up to the pin and gave it 3 taps with a hammer and it was out!
Best tool ive used so far.
