Noobie Needs help picking swap for 99 hatch
Hey guys got myself a 99 hatch for this summer coming up looking for a good swap to run something fast and decently reliable I'm not looking to do a k cause I don't have the money I was thinking of either an lsv poor mans type r or something else depending on what u guy think right now it has a d15 Vtec in it and I don't wanna be slow this summer lol thanks for the help guys
The Grumpiest
Re: Noobie Needs help picking swap
^^^This.
Get the biggest engine with the most horsepower that you can afford. If you don't know how to do a swap yourself then consider asking some to help you that does or pay someone.
H-T White Ops
There's a few different points you should think over before you decide upon and purchase your new engine.
What are the legal swaps in your area? Sometimes there are limitations. Some areas, for example, will not allow a "light truck" engine to be swapped into a car. Other areas will only allow engines of the same year or newer. Will you be required to pass emissions or BAR?
What other parts will you need to replace for your swap? Are you willing to modify your car in that way or is there something you dislike about it? Cutting out your old mounts and welding new ones in might be a no-no in your opinion. Do you "require" VTEC? Are you okay with mismatching an engine together or would you prefer a more K.I.S.S. approach?
Will the engine really suit your needs? The fact of the matter is that an expensive engine that only runs on jet fuel just might not be a reasonable daily driver for us all. Would a high or low compression engine be better for your uses? Do you plan to modify the engine later? Any idea how you might? Are you okay with using premium fuel or would you rather the car runs on regular? Would you prefer to have as much power out of the stock motor or are you doing an eco build?
Don't forget to do any possibly need service to the engine. Has it had it's water pump and timing belt done? Don't forget the price of additional items and fluids.
Now write down the engine swaps you can think of and mark down any concerns or complaints you might have with each. Some might be easily marked off the list and others might stay up for debate for a bit. Hopefully this will help keep you from buying an engine that you end up not wanting.
Money is obviously a concern --and bang for buck, you can set up a junkyard turbo for cheap.
There's not much info in the post, i.e. hows the engine in the car running? etc etc. If the engine is in good shape (lets assume it is, because OP just said he wants a swap to "be fast for summer" not it needs blah blah blah)
So, speed and money are a concern.... Your opinion is that the B swap would fix both these problems. Ill stand by my opinion that cheap and fast is with the turbo.
Another thing is....everyone I know that has swapped, has loved it for 4 months...then always thought, man I need (whatever the next step up is). Get a b16, youll then want a b18c1, then a c5, then a K swap etc. At least thats what Ive always seen. I mean, you have a 120hp civic, and you get a 160 hp civic and its great, til you ride in a 180hp one, then you see 200 hp...etc etc etc.
Being fast for the summer means....well lets be honest, racing... once you start modding...you arent going to stop, you just run out of funds.
i agree on getting the best with what you can afford. If you can swing it, i have always loved a B16B. They arent too expensive, super fun and reliable, and plenty of options to make it alot better. Best middle of the road swap in my opinion.
@OP if you want to go fast and you have a D15B VTEC. Then Put a small turbo on it and tune it. Don't run too much boost but you can easily get 220WHP out of it and have it be reliable. It will be faster than any B swap and considerably cheaper. If you really want to go B series then do a LSV or a B20V, just don't rev them too high or you will kill the bottom unless you are very lucky. GSR's are a waste of money IMHO.
you think its harder to set up a junkyard turbo then doing a b swap or ls/vtec etc?
Location: Pensacola, FL and every Court House in Louisiana
Also shop around and take your time. I found a 99GSR complete swap with 80k miles and new timing belt and water pump and a BNIB Skunk2 pro IM for 1500
H-T White Ops
There are many swaps which can be purchased and installed for significantly less than the K-series.
The problem I see with doing a junkyard turbo and running the car until the engine blows (as you stated) is that later on down the line you're going to have a car that suddenly does not run. This could be highly inconvenient.
The OP has not stated that the car is having mechanical issues. He only states that he doesn't want his car to be slow this coming summer since it only has a D15 VTEC.
So for now the OP has a running car, but it's slow. He can put together a reliable build (do it right the first time) and put that into his car at his leisure.
I'm not here about doing things on a budget and just upgrading when you have an emergency. I would rather have a good base I can improve upon in the future, which is still highly reliable until then as well.
I do not envy the people I know with stock Civics with junkyard turbos. Most of them are budget builds, ghetto rigged together. Of the ones I've met, often these are the people who would like a faster car, but they just plain do not have the money. So they scrape by with as cheap as a build as humanly possible and then they have problems down the line.
This isn't to say that it's not possible to have a reliable car out of these parts, but in my experience it's not likely. Plus swaps are just so cheap to begin with. The OP doesn't REQUIRE a swap or a turbo, so he can just keep his eyes out for the right deal.
I was mentioning those things to give him an idea of what he might want to look into as far as the law goes before he swaps.
If there is some kind of law it is not enforced at all. You could roll into a police station and have the car checked and not get in trouble for having a lower year motor.
Thanks for all the replys guys I'll try to answer everyones questions I'm in Toronto so there isn't a problem with swapping motors and I'm not the greatest with swapping so my buddy is gonna help me out but ya as for motors I've always wanted an itr motor from the begining the reason I haven't got one is cause there almost 4000 in most shops I said I wanted an ls vetch because my buddy had one and it was pretty quick full skunk 2 head intake manifold and 70mm throttle body and the bottom end was itr pistons or Ctr I can't remember but it was nice and quick same with my buddy's poor mans type r in his crx I was looking at those kind of things to build or an ls motor on boost I would have boosted my single cam but it's been beat to hell and back from previous owner I was going to build a b16 but everyone says its not worth it my bugget would probably have close to 5000 maybe a little less depends how Christmas goes
