d16 injectors/fuel rail...
Well next i would like to do injectors and i guess a fuel rail to go with it. I have a slightly built d16z6 N/A.
Ive already got most bolt ons and a comp cam and AEM cam gear. Anyone have a good brand for injectors and a fuel rail they would suggest? Also which ones to go with. cc wise...
Thanks
Thanks
Seagull Management
Re: d16 injectors/fuel rail...
What kind of power are you planning to make? I can't see making enough power to actually need anything bigger than stock, and if you did stock H22 injectors would certainly be enough.
quit playing with ur *** and turbo it ...lmao as stated above its a total waste of money its not gonna do anything and you wont make no more then 140hp on a n/a built stock block without raising compression. And no one has ever made more then 170hp from a fully bored and stroked block ,p&p head cam etc... you can slap a turbo kit on there and make that for half the money without building the block at all. then if u ever decide to go this route you may wanna upgrade your injectors.
What are you tuned on? Hopefully, you tuned the cam in and that you plan on tuning new injectors in.
I was making 170whp/150wtq on a JRSC on 7 psi and still used the stock injectors. They were maxing out at that point, but for your build, just stick with stock.
However, if you MUST purchase aftermarket injectors and fuel rail, I have never had a problem with RC injectors and AEM fuel products. RC 310's (I think those are the smallest) would be best.
Matthew98DX
10-31-2016 06:28 AM
SolAssassin
11-23-2009 03:20 PM
