honda civic starting problem.. help
Hi. I got a 1993 honda civic ex with a b18c1 (Gsr) in it.it was running fine up until a couple days ago. Everything started up fine and then it just wouldn't start. It starts when I push start it. Right now it doesn't make that clicking noise from the starter, so im kinda lost. If anyone can give me some advise that would be nice.
Re: honda civic starting problem.. help
first check your motor grounds and make sure they all have good contact. a weak contact or corroded ground will not turn over the starter and it will just click.
I tried all that, but it doesnt start. When i turn the key to try and start it, it doesn't make the clicking noise like it normally do. I changed the starter out to a different but it does the same thing. I changed the main relay but still does the same. Any info on where the "starter relay" is? or how to jump it from the starter?
Jack Murphy
06-21-2017 06:23 PM
