any tutorials/pics on installing front SI sway bar?
I have a front 99-00 civic SI sway bar with the LCAs and damper forks. just wondering if anyone can give advice or a how-to to help me out. damper forks are easy, just wondering about the sway bar and LCAs. pics would help. TIA
99-00 SI sway bar, LCAs, damper forks going on an EK hatch BTW
[Modified by deviant1, 12:42 AM 1/25/2003]
Re: any tutorials/pics on installing front SI sway bar? (deviant1)
what kinda help you need. i did this a few months ago on my car, piece of cake. Pm me if you have any questions. later
Re: any tutorials/pics on installing front SI sway bar? (SilverCivic2k)
do you have to grease the bushings in the lower control arm? or just bolt everything up? is there supposed to be protective caps on the endinks? can you use your stock bolts for the damper forks? can you use any of your stock hardware for that matter? or do you have to use ALL 99-00 SI hardware like the bolts, nuts, etc...
Re: any tutorials/pics on installing front SI sway bar? (Peagreenhatch)
can you use your stock bolts for the damper forks and LCAs? or must the 99-00 SI bolt and nuts be used? i know you have to use the 99-00 SI bolts for the sway bar brackets because stock EK hatches dont have those bolts. also, when installing the sway bar, must the front of the car be suspended in air on jackstands? or finger tight bolts while its on jackstands and torque them down when the car is on the ground?
Here's some simple directions for the si lcas, forks, and swaybar install:
http://patriot.net/~merritt/frontbar.html
If you want to see if you'll need new bolts or not, go to http://www.hondaautomotiveparts.com and compare the Si bolts against the bolts for your car and see if they are the same.
Re: any tutorials/pics on installing front SI sway bar? (EricUSC)
where do the endlinks screw into on the LCA? is the hole on the LCA threaded? or is there a nut that screws onto the endlink?
Re: any tutorials/pics on installing front SI sway bar? (tominos)
so what needs to be removed or loosened in order to install this setup? you have to drop the shift linkage, but do you have to disconnect the exhaust/cat?
[Modified by Airbag Club, 12:28 AM 2/10/2003]
Re: any tutorials/pics on installing front SI sway bar? (Airbag Club)
U do need to loosen the exhaust because the sway bar goes over it. Make sure u put ur car on jackstands and high enough cause working under there without some room is bad, besides, when u take put the sway in, u will know u do need room.
Here is a site that might help u, but is down right now. Try later.
http://www.geocities.com/MotorCity/G.../fswaybar.html
Re: any tutorials/pics on installing front SI sway bar? (HondaCivicEx98)
couple questions:
1) do you need a new exhaust gasket when disconnecting and rebolting the cat?
2) what bolts/nuts can be re-used from the stock civic?
3) what bolts/nuts from the 99-00 SI do i need?
4) do the endlinks bolt into the little tab that has a hole in it that sticks up from the LCA?
5) do i need new cotter pins for installing the new LCAs?
6) do any bushings need to be greased?
you remove the LCA from the car, so why wouldnt you need new cotter pins? just like when you take axles out, you separate the LCA from the car and remove the cotter pin on the castle nut.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicEx98 »</TD></TR><TR><TD CLASS="quote">U do need to loosen the exhaust because the sway bar goes over it. Make sure u put ur car on jackstands and high enough cause working under there without some room is bad, besides, when u take put the sway in, u will know u do need room.
i just want to say thx for the comparison link!! hehe
deviant1
06-07-2003 12:55 PM
