Do 99-00 Civic Si front LCAs and forks fit in 96-00 Civics w/ SOHC motors?
Do 99-00 Civic Si front LCAs and forks fit in 96-00 Civics w/ SOHC motors? Is their geometry the same as those found on the EX, except they are lighter and the swaybar mounts differently?
Re: Do 99-00 Civic Si front LCAs and forks fit in 96-00 Civics w/ SOHC motors? (EricUSC)
Re: Do 99-00 Civic Si front LCAs and forks fit in 96-00 Civics w/ SOHC motors? (Supertwinz)
The 99-00 si LCAs and forks are same as EK4/EK9 and they would fit with any d or b series motors. Geometry are the same. This upgrade is a must if you planning to use 26mm and up front swaybar.
Re: Do 99-00 Civic Si front LCAs and forks fit in 96-00 Civics w/ SOHC motors? (WOLFPACK)
yep you got it exactly man. It is same thing just lighter and needed in order to fit SI front sway bar.
Re: Do 99-00 Civic Si front LCAs and forks fit in 96-00 Civics w/ SOHC motors? (SilverCivic2k)
Just curious, but how much lighter are the SI lcas and forks? TIA
datssoled
06-20-2008 10:12 PM
cruzersi99
23
02-17-2006 08:21 AM
kyden
06-29-2005 05:42 PM
