Has this been done...
I was wondering if anyone has ever installed a remote ignition into a manual civic... I know, just waiting to get ripped off if someone finds your keys , but still... Anyone? If so, was it hard to install and what did it intale
... thanks
... thanks
Re: Has this been done... (binkster)
... thanks
... thanks
YOUR keys are attached to the remote start.
The point of remote start won't matter, cuz if the thieve remote starts your car, HE already has your keys
Yes it can be done, but I think you will regret it when you leave your car in gear one day, go to remote start it and then watch your car get owned by a post because it tried to get moving when it was in gear.
[Modified by ransack, 11:13 PM 1/24/2003]
Re: Has this been done... (ransack)
Re: Has this been done... (delslow94)
All Compustar alarm/remote starters can be used with standard or auto. When you set your e-brake then turn you car off the car stays running till you shut the door. If you leave it in gear and you can pull that off I will give you props. If your doors are open after that it won't remote start. HTH
Former Moderator
I *think* he means like a remote kill switch in order to shut the car off if stolen?
I don't really now what he means. If he means a remote starter to hit a button to start the car then yes it's been done a million times.
Funny thing is when people leave the car in first gear w/othe e-brake on and hit the start switch - can you say damage?
Solbros Owns Me
Re: Has this been done... (MonsterVTEC)
all the remote starters I've seen have certain "rules" in order to work. The car has to be in neutral and have the e brake up. If you're stupid enough to leave it in gear and then try the remote start, then you deserve the end.
I dunno about you, but I always leave my car in neutral and pull the e brake. Also, if a Honda starter had enough power to move your car fast enough WITH the e brake engaged, and move it fast enough to cause damage, then Honda gets a from me,
Re: Has this been done... (Emerica)
what makes everyone think that an engine starter can more a car faster than an old granny on trainning wheels? ive done it a few times on purpose (*with my older paseo LOL) and it barely creeps, and thats with constant starting, those remote starters only engage the starter for like 1-2 seconds...that will only move a car forward like 1-2 feet if at all.
*why i way driving with a starter: ran out of gas one day, was too tired after pushing the car for 25 minutes, and got stuck on a little storm drain and had no momentum to push past it...so i put it in 1st and turned the key, got the car over the lump...and was on my was to pumping gas...those were the days LOL
Re: Has this been done... (chrisr)
Then open it back up and put it in gear... but why the fudge wouldyou do that?
User: neonxrt on here has that alarm system in his car and it's manual, he's never had a problem.
I have had it on my civic for 2 years its great when its cold outside, press the button from inside and let it warm up and the e-brake has nothing to do with it.
you can do it on manual cars, but you need to bypass the cluch pedal switch...and if you leave the car in gear it will jump....it can be done just like in a automatic car...as far as it getting stolen theres a break kill switch you hook up that when ever you press the break and the car is remote started it will shut off the car, just put that on the clutch too.....no worries.....if you need to know what to buy get a Viper 551r it has a keyless entry integrated into the remote start....However you have to install it because DEI wont let certified installers do the work...I know this because I am one....so good luck
Guest
Posts: n/a
A friend of mine had remote start on his Si.... One day he left it in gear, and in his apartment, sat on the remote. Next thing he heard was tires screeching and a loud crash... his Si jumped into traffic and got hit by a pickup truck...
jus f0 dekarayshunZ
Re: Has this been done... (V8 Killa)
i got a question....is it even worth it? spend your money elsewhere like on an alarm or something useful....you dont need that crap...its not worth the risk imo...if you want to waste your money then go ahead you earned it
Location: chillin in that city called queen creek, but homes the atl
Re: Has this been done... (CiRcUiTsi)
u guys are always so negative. i have a remote start on my civic only because it came with the alarm, but to keep it from starting when left in gear is to us a sensor that is wired to a relay that will not let the car start while in gear the sensor i user is basically the reverse light sensor
Re: Has this been done... (streetdreams02)
i have it on my eg. its a stick also ...its cool when its cold and hot outside because you can have the heat or ac turned on....it is dangerous though if you leave it in gear though....you get pretty used to not leaving it in gear but its dangerous when you let friends borrow your car and they leave it in gear and you dont know it adn start the car...(ex) friend picked up his car from mechanic and busted his radiator when he remote started and had to leave it there....but if you engage the ebrake hard enough then the car wont really move that much. it only moves about 1 foot. its fun to start it ingear in an empty parking lot and just watch it drag along
compustar and those aladdin alarms have remote start where you have to put it out of gear, and get out of the car, and close the door, and put the ebrake up before the engine shuts off.
junkspeedproject
Audio / Security / Video
28
01-16-2008 04:55 AM
samvong
10-23-2005 08:45 AM
