Is it possible to legally smog a LSVtec
Re: Is it possible to legally smog a LSVtec (Spooner)
Is that really all it takes? I thought it would be more complicated since it's a head swap?
Re: Is it possible to legally smog a LSVtec (RSZero1)
If it were in a teg, I would say you might be able to slide at a normal smog station, but if its in a civic they will most likely catch it and tell you to ref it, and the ref will know a non vtec block and a vtec head; so you wont pass his inspection. It could go either way, but Im going toward not.
nope...can't smog it...emissions are way too high...nitrogen dioxide is too high. my friend's readings were like 115% higher than the allowed emissions level. he had a LS/VTEC setup...good luck...
Re: Is it possible to legally smog a LSVtec (acydphryck)
okay, i thought so, couldn't be that easy...hmmm, how about if i reffed the ls in the civic first, get the bar sticker, then did the head swap? They would still pick up the violation at my next smog huh?
Re: Is it possible to legally smog a LSVtec (Spade)
Okay, then scrap that idea, guess the LS/Vtec is track only unless i wanna go the illegal route...too bad though i think it'd be fun - expensive, but fun...lol
would cops know the differnece between head and blocks?
lets say you get a BAR sticker for the ls. then later on you want to slap a vtec head on it, would the cops know the difference?
Re: Is it possible to legally smog a LSVtec (lazyvietboi)
when i went to the smog ref on tuesday......the guy said that i could LEGALLY swap a VTEC head on my LS non-vtec and still be legit............he started saying what i would need....like the knock sensors etc............so i would ask some ref...... .
Re: Is it possible to legally smog a LSVtec (speedaholic92)
cool, THAT's what i needed, which station did you go too? so i can call...
Don't believe the bullshit. It HAS been done. You have to remain pretty much "stock", though. Good luck.
Re: Is it possible to legally smog a LSVtec (Blake K.)
u could always go the..."expensive" way...
*edit - ask spade, he's a genius at this kinda stuff.
here's his thread https://honda-tech.com/zerothread?id=385337*
[Modified by all stock, 1:48 PM 1/24/2003]
Re: Is it possible to legally smog a LSVtec (rodrez)
it can not legally be done. honda never made and lsvtec as an engine so a ref wont smog it. although i have heard from a shop that he has seen many pass. you just have to find a place that will do it for you. if it dosent work at one then goto a nother.
keith
keith
Re: Is it possible to legally smog a LSVtec (kwil666)
A friend of mine passed with a lsvtec in an 89 si hatch, the smog tech didnt know that it wasnt the right engine.
Re: Is it possible to legally smog a LSVtec (BeerBaron105)
lol, is this really possible....i suggested this once before and someone said the car wouldn't move,lolz, and im guessing high flow cats wouldn't help either
