2 questions about an JDM ITR rear sway bar.
ok i just bought a jdm 23mm rear bar. And i have 2 questions.
1. Will all the all the hardware for a usdm rear bar fit the JDM(i.e: d-bracket, endlink bushing +collar etc.)??
2. what lcas do i have to use?
Car is a 92 civic dx hatchback. Thanks for the help!
Mike
[Modified by Mike D, 2:06 AM 1/24/2003]
Mike
Re: 2 questions about an JDM ITR rear sway bar. (Mike D)
HTH
Re: 2 questions about an JDM ITR rear sway bar. (CRX25)
you may need to drill a hole in to bolt up both bolts for the d-bracket. I dont think the dx came with a sway bar, so then you would need either a gsr or an si lca. or itr if you are going with itr suspension
HTH
1 Post
2. I believe that you can use either, LS, GSR, 4 dr 92-95 Ex or ITR LCAs
i have a itr rear sway bar on my eg hatch i used the d bracket and bushing for a itr. i used integra gsr lower control arms, and end links. i used a great product from beaks performance , they use billet brackets to secure the bar to the subframe, i heard alot of people tearing bolts out of the subframe because the bar was so big. i hope this helps you out.
Re: 2 questions about an JDM ITR rear sway bar. (khcivic)
Thanks for the response guys. Im going to post up the first question in the type R forum and see what they think.
i just got all the parts from my local acura dealership today. i got the front and rear itr swaybars from john @ passwordjdm.com and ordered the front bolts + nuts for the brackets, the endlink bushings and nut was already there. and for the rear the beaks kit will cover the bracket nuts and for the endlinks i got the long bolt and washer that goes on the D-bracket. bushings and all were already there, but usdm stuff will of course work.
if you need pics of anything let me know.. have everything liying here
you will need a rear reinforcement kit. wwww.beaksproducts.com
Re: 2 questions about an JDM ITR rear sway bar. (chameleon)
Thanks for the help chameleon. I wasnt sure because i read an archived thread about someone have issues with using the d-bracket for a usdm bar, with the jdm bar. Didnt know if the 1mm made a difference.
Im ordering all the **** from acura too, im guessing all the brackets and such came with their respective bolts?
Also, what size is the front bar you got? same as the 24mm usdm?
Thanks again!
Mike
Thanks again!
Mike
[QUOTE]
bwahahahah, i got a 26mm monster!!{/QUOTE]
damn thats huge! what kind of spring/damper combo will you be running?
Mike
Mike
Mike
Mike
im gonna run ITR Spoon/Showa dampers.
oh and 10k fr and 8k rear.
[Modified by chameleon, 11:54 PM 1/23/2003]
