hard wiring a horn?
hard wiring a horn?
i took off my stock 94 cx airbag wheel. no horn. i guess i am going to have to hard wire it, anybody know the easiest way to get it to work. i am tring to use the button horn for my grant wheel. just a round button with two metal tabs on the back. please help me asap! thanks in advance
Re: hard wiring a horn? (SOHC Beast)
lol, this may sound ghetto, but hear me out... i did the same thing i got a 94 dx... its been a while since i did this but i think thur wur like 3 wires in a white peice of thin-*** plastic... 2 are for the airbag, forget bout them... the other one is for the horn. now ride 2 a local radio shack, find wut looks like a black bungee cord its with cellphone adapters n ****, its called "adaptaplug" but the longest one (like 10 ft) then get two plugs 2 go on each end, solder one end (both wires on the connector) 2 the thin-*** horn wire... secure the plug to the steering column sum how, zip ties w/e u'll think of sumpthin. then thurs a hole at the bottom of the plastic steering column cover (take the piece of metal off the plastic thing, u don't need it remember weight is the enemy and anything xtra must go) run the bungee-wire thru that hole and let it hang down then run the other end up thru the adapter u got on the back of the steerin wheel and u can proly figure out the rest.. good luck! if u got questions im me at hondadazed
Re: hard wiring a horn? (hondadazed)
