how do i get that annoying ding to stop when keys are in the ignition?
I have a 95 eg and i hate the ******* dinging that it makes when the keys are in the ignition. Anyway to disable it but not using the pin on the door that controls both the dome light and dinging?????????
thanks Spencer
[Modified by spencedogg, 3:51 AM 3/8/2003]
thanks Spencer
Re: how do i get that annoying ding to stop when keys are in the ignition? (Spade)
LMAO... funny reply...
or you can try taking out the plastic panel from the back, and under near the door, is a plug for the button on the door... disconnect that... See what happen and tell me if it worked, Im guessing here....
Why would you want to stop the noise though it reminds you to take ur keys b4 you leave....
Angel
Angel
Guest
Posts: n/a
Re: how do i get that annoying ding to stop when keys are in the ignition? (spencedogg)
or try this just take the panel from the pasanger side its a boxy looking thingy called the ECU ...and just give it a few jerks till it comes out ...should be set
If you just need to disable it temporarily pull out the dome light fuse, its a 7.5 amp i think. I always do that when im workin on the car and im gonna have the door open and the stereo on.
Take it one step further and wire a toggle switch in line with the fuse, if you want to disable it often enough and dont want to always pull the fuse.
Re: how do i get that annoying ding to stop when keys are in the ignition? (ninetfivehatch)
uhh i just click it forward. then it beeps a couple times in long beeps and it goes off..lol
Location: Why so you can pretend like youre interested, FL/OK
Re: how do i get that annoying ding to stop when keys are in the ignition? (all stock)
It's kinda handy sinceit reminds you that your lights are on too.
Best suggestion listed was to actually remove the 7.5 fuse for the domelight, of course you have no domelight, but it will eliminate your problem. I used to remove this as well when I could not close the door completely while working on the car.
