zex cam and nitrous?
Re: zex cam and nitrous? (tek_civic)
ttt. the guy who was going to help install it said to make sure that i check first to see if they can be used together or i could hurt something. if anyone has some info please let me know.
do have spring and retainers with that cambecuase i had the same cam and i reallyliked it but i blew my motor. i would suggest port and polish the head and build the bottom end before nos you will not regret it. Not to flame you but on your site it says you ran a 18's 1/4. when i had my sohc with i/vtec controller i ran 16.1 @ 87mph and with cam i/h/e/vtec controller 15.3 just to give you something to compare to.
Re: zex cam and nitrous? (JSPECEX)
i know someone spraying a 65 shot with a dry kit and that cam on stock head and bottom end in a d16z6. engine has 99,000 miles and he has no problems.
edit: the zex cams are made for nitrous
[Modified by cjames235, 12:45 PM 3/10/2003]
The springs and retainers are a good idea but you don't have to build the bottom end for a 50 shot.. and since you are getting a ZEX kit, don't bother with a wet setup, their dry 55 shot is what you are looking for, it will be reliable and cheap.
