b18b --> EG rear mount question
Alright, I'm having a bit of difficulties with this swap, sad part is it's supposed to be a direct and easy one. I purchased 3 different rear brackets from several wrecked LS' and none of them fit properly.
The final bolt is offcenter and the holes NEVER align
WHAT MOUNT DO I NEED EXACTLY?
Any help is appreciated, thank you.
Andre
Andre
Re: b18b --> EG rear mount question (slo95cx)
The mount should be from a '94 and up integra. I was able to use the one that came with my swap from a '96 LS. If I remember correctly that was bitch to get aligned with the bolt. Try doing that mount first.
Good luck,
G
Good luck,
G
94+ teg
there is some mounting hassles, just like when I dropped my b16 in my ef... I lowered the motor in and placed the mount bracket in the area where it should be bolted in... once I got the two main mounts (tranny upper and drivers upper) THEN bolt in the bracket. I think the mount stays the same, bracket is different.
HTH
HTH
FortunateFool.
08-13-2002 08:17 AM
