Replacing antenna on 94 hatchback....
Banned
My antenna got bent and i got a new one but i dont know how to install it. Does anyone have any installation help w/ an antenna?
thanks
thanks
Re: Replacing antenna on 94 hatchback.... (blykins)
PITA......you have a lot of crap to remove to get to it.
1. Radio
2 Dash
3 Side molding
Off the top of my head.
1. Radio
2 Dash
3 Side molding
Re: Replacing antenna on 94 hatchback.... (Spade)
If you remove those 2 screws that hold it down the the body of the car and then remove the plug that goes into the back of your head unit, you can pull it out with a little bit of effort. Replacing it....never put one back in. I would assume that if you got a coat hanger and taped the antenna wire to the hanger then pushed it back the way it came out and then routed the rest of the antenna wire back to where its supposed to be, maybe that would work out?
Re: Replacing antenna on 94 hatchback.... (b16a ferio)
Tie something to the end of the ant. that plugs into the radio BEFORE you pull on it if you don't you will wish you would have
austinwith96civic
03-11-2010 09:49 AM
rice a roni
05-31-2006 11:48 AM
