Need to know all miscellaneous parts needed for B-series swap(I already searched).
I have a 93 Del Sol Si and I'm just looking to see all the extra LITTLE miscellaneous parts needed for a JDM B18C1 or C5. I know the basic engine, tranny, ECU, Del Sol Axles from the VTEC model and the shift linkage. But I always here about "this part doesn't work with this car or you need this from this integ." When I do my swap I really don't want to have keep running out to the parts store or the salvage yard. I want to get everything before I begin. I know I am asking a lot but can I also get the list of miscellaneous parts for a 96 Civic Coupe EX. We are buying our motors on Tuesday and will be completing the swaps whenever they arrive together at a shop. We will be doing it ourselves so all advice and help is appreciated. I have done SOHC swaps and tranny swaps but an engine swap is a whole new ballgame.
OH I SEARCHED AND SEARCHED AND SEARCHED. Maybe I asked the wrong question but I could not find the right information.
Re: Need to know all miscellaneous parts needed for B-series swap(I already searched). (jigga008_99)
motor tranny ecu axels all the mounts from where the motor is from...shift linkage...and if your car isnt vtec....you need to wire that up.. and also the IAB for the secondary butterflys..and make sure you dont have a OBD2 ecu or else you need a adapter...if its a C5 for sure you need an adapter if your using the stock ecu.. and you need all the integra **** for power steering and AC
New User
try http://tech2.hybridgarage.com/index.html they have all the info
you need that where i got mine from..
good luck
good luck
vain
07-13-2003 04:04 PM
