First Motor swap
Frist Motor swap
Too all that can help. I have a 94 Si hatch and I want to swap the mtor but don't know what motor to get I have so many ideas but I don't know what to go with I want to do an H22 but I was told that keeping up with it can be a bitch and it takes some money, money I don't have so I was wondering what would be a good motor for my frist swap thanks everyones help.
Anthony
[Modified by MonsterVTEC, 5:55 PM 3/7/2003]
Anthony
Re: Frist Motor swap (crxgator)
i think h22a is a cheaper swap than b18c...
[my .02]
gsr is best bang for buck
type-r is overpriced (and if boost is an option you've got more compression to worry about)
b16 is too small (and you want stock Si's to run with you??)
b20 is alright but no vtec
b20vtech is kinda pricey, but #2 on the list
h22 is too expensive to install
[/my .02]
Re: Frist Motor swap (turbocr-x)
get a GSR in my opinion...
if you dont wanna spend much money and just want an OK swap with a stronger vtec...Id go with the B16a2...A little cheaper than the GSR and still has a bit more power than stock...
Id still save for the GSR though..
good luck
good luck
Re: Frist Motor swap (Feuerraeder)
[my .02]
[/my .02]
[/my .02]
My fav swap is a C5 and a Black valve cover. Less worries.
But, 1.8L VTEC or go home.
H22 is nice but will cost as much as a C5 done properly. I.E. mounts = 650, axles = 300 and labor is stupid. All that for 150 ft-lbs. Nah.
how is a h22a more expensive to install than a b18c1...
JDM H22A:
engine/tranny/ecu-$2200
mounts- $550
total- $2750 and has more hp and torque
JDM B18C:
engine/tranny/ecu- $3150
JDM H22A:
mounts- $550
JDM B18C:
JDM H22A:
mounts- $550
JDM B18C:
JDM H22A:
mounts- $550
JDM B18C:
Re: Frist Motor swap (Si.Hatch.92)
dude search there is sooooo many posts about motors and which is better or which is worse. IBTL tom's gona get ahold of this ****.
Re: Frist Motor swap (slammed_93_hatch)
H22 all the way! Its not as bad as some say it is and the HP is well worth it.
or
the Si you have now is not to shabby, Id look at getting a turbo.
or
Re: Frist Motor swap (MonsterVTEC)
Anthony
Anthony
si are heavy...im talkin from expierence i have a 93 si with a gsr and it is alot faster then SOHC but im now lookin to buy a CX or VX and swap everything over...my 2cent
but good luck anyway
H22ACiViC
01-08-2002 10:11 PM
