Wrecked my DA Got an EG NEed help
I totalled my 91 Ls Integra, the engine tranny and most parts are fine. Im buying a 92 vx on monday. What parts do I need to swap my b18a into the civic. Im wondering about the ecu since my engine is non- obd and if its gonna be bitch to get in. Also what axles, motor mount and shifter linkage is necessary. If someone could make a complete list it would help out a lot. thanks guys
Re: Wrecked my DA Got an EG NEed help (FASTEG)
you will need to change the distributor, injectors and ecu to OBD1. USE 94+ integra mounts. 94+ integra throttle cable and fuel line, 94del sol vtec air condition mount if you want to keep your A/C, you will need to wire in a knock sensor, and change to a 4 wire O2. Thats all I can think of right now.
Re: Wrecked my DA Got an EG NEed help (92tealvx)
to correct you, you dont have to wire up a knock sensor unless your running a vtec ECU(p72,p30) since its a LS motor that he's putting in, theres no need to wire a knock sensor...
you should do the 4 disk conversion, can go wrong with all the stopping power.
good luck
good luck
Re: Wrecked my DA Got an EG NEed help (DOHCtorTHRUST)
If you would have gotten a EF, most of the suspension would bolt up too. but eg's are cool too. just part out things that don't fit.
good luck
good luck
